Old 01-10-2005, 05:57 PM   #1 (permalink)
1BadTitan
1BadTitan's Avatar
Installing Eclipse avn2454 Need help!!!
OK first the factory side mounting brackets will only attach to the front two or the back two holes on the unit. depending which ones I use depends if it sticks out to the dash hole or sits flush. Which are we using? Also someone posted that the speed sensor wire was the #24 on a 24 pin plug...The diagram states the wire is at the cluster and its white/red stripe. Well there is a wht/red wire in that connector, its #1. I just want to be sure so I donty have to pull this thing out to make changes. Any help would be nice.
[color=Blue]1BadTitan
