The diagram for the RF system without navigation indicates the speed sensor wire is W/R and on pin 24 of connector M98 that plugs into the A/V switch. The other end of that wire is on pin 29 of connector M24 which plugs into the combination meter.
As to the position of the mounting ears: I used a single DIN radio in my install and need to modify the mounting kit to get a proper fit. As I remember the dimension it is just a little more (about 1/32 inch) than 2 and 1/2 inches from the rear of the mounting ears to the front edge of the radio. This permits the front edge of the radio to fit against the rear edge of the double DIN bezel.
