Titan4x4Aggie's Modified Sub Box
Hey All! This is my first post. I'd like to thank Titan4x4Aggie for his awesome write up on the custom sub enclosure. All props to you man.....
I took the sub enclosure that Titan4x4Aggie drew up and modified it slightly. First, I used all 3/4" particle board instead of 1/2" on the top and bottom. I also chopped 3/4" off the front, back and side pieces. Next, I didn't offset the side pieces, instead I made them flush with the others. Finally, I put the terminal in a slightly different spot and I recessed the sub mount. Note that all seams on this closed box were sealed with a healthy amount of silicone caulking as well as around the lip where the sub sits. I'll be finishing up the carpeting tomorrow and stuffing the heck out of it with some polyfill. Also be aware that this box does fit a 12" sub!!! You have to cut into the walls a bit and move some screws around, but believe me, it'll fit!! Oh yeah, I forgot to tell why I chopped off 3/4" from the front, back and sides......1) to make up for not using 1/2" on the top and bottom, and 2) to gain additional clearance under the rear seat (this is also why I recessed the sub, plenty of room to move some serious air, especially when you're pushing 1000 watts!!!)
Good luck on all your DIY's!
