Old 02-03-2005, 07:22 PM   #9 (permalink)
6thsense
6thsense's Avatar
Originally Posted by jeeptug
They are no longer replacing beds. They will only replace under the most severe of cicumstances.
Sounds like the fix for yours is just to cut the bubble open and see if it is sticky underneath. If it is they have to remove enough untill it is not sticky anymore and then replace what was removed. If it is not sticky under the bubble they will just apply some adhesive and stick it back down and then touch up the cut. I recieved a copy of the repair the other day and read through it. They do not mention what they will do if the delame is more severe. I would suspect that they would then contact Nissan and they would send someone to inspect and advise.
Nissan has contracted with Rhino to do their warranty repairs but they do not spray Rhino material for the warranty repairs. They spray an aftermarket version of the ppg material that was applied at the factory.
Did I confuse everyone.
since when are they not replacing beds anymore.....just had my bed replaced due to 2 nickels sized bubbles....if this is the case....that sucks bigtime....also, they replaced my 04 bed with an 04 bed....good luck!
6thsense is offline   Reply With Quote
