Originally Posted by nursecrickett
What does this lift do? How high does it make it? Just level, or all the way around?
Well, first of all, it's not really a lift in the traditional sense, it's a leveling kit. It is a billet aluminum spacer that relocates the upper mounting point of the front strut approximately 1.6" lower effectively raising the front stance of the Titan by about 2.5". This will level out the truck. The rear is untouched with this kit.
Follow Up: If you have the 4X4 Off-Road Package, Greg makes a 1.2" spacer that will raise the stance about 1.75". The reason for the shorter spacer, as I understand it, is that the Off-Road Package has a stiffer spring to begin with so the front stance is already advantaged and doesn't need as much lift to level the truck.
