Old 02-19-2005, 09:43 PM   #15 (permalink)
andy
andy's Avatar
Results:
I pulled the rubber plastic-like weatherstripping seal that goes around the window on driver side. I only stuck some velcro on the inside side of the metal that the weatherstripping slides over. It still makes some creeking/flex noises but is way quieter than before and I must say I'm enjoying the drive again.
The only priblem is that the plastic looking part that is on the inside kind of has a gap that runs all the way around now. About 1-2mm. Oh well. At least it's quiet now.
This is what I personally think the noise is: the weatherstrip seal is a hard rubber almost hard plastic material. It seems to amplify any noise. Try tapping on it with your finger nail, then tap on the rubber on the body side.
And for some reason is vibrating or sticking to the metal. Then the plastic amplifies the noise. Then it sounds like a flexing noise.
andy is offline   Reply With Quote
