Old 02-25-2005, 09:10 PM   #7 (permalink)
4x4creature
4x4creature's Avatar
Originally Posted by Bayou Titan
Most air compressors are manufactured by either Campbell Hausfeld or DeVilbiss and are marketed under dozens of other names such as Craftsman, Speedair, Porter Cable, Husky, Delta, Iron Force, Power Pro, etc.
Campbell Hausfeld model VT6300 which sells for $417.00 has enough power to do anything you want. It has a 26 gallon tank, solid cast iron twin cylinders, and the highest rated motor that can run on household current.
It is a portable unit which makes it easy to take somewhere else.
http://www.chpower.com/
This good advice, especailly on the cast iron jugs, just besure that the heads is also cast iron.
The Creature
4x4creature is offline   Reply With Quote
