Old 03-03-2005, 10:30 PM   #13 (permalink)
m95roadster
m95roadster's Avatar
Originally Posted by smoketitan
as far as the tweets go
1) in the dash it reallover powers the midrangfe so I needed to use time alingment to delay the tweets so it didnt overpower the midrange and crossing them lower also helpo (arounf 2500-3200hz)
I run active by the way
2) if you are using the passives I think the best best is in the apillars or the kicks
Im going to glass in some kicks/and the a-pillars this weekend to see how it works down low aimed or on the a pillars at my ears
but from what I found is that the mids are soo low in the door its ahrd to bring them together (mids/tweets) with the tweets so high unles you delay the tweets using time alignment
Cool...thanks for the heads up! I usually place the tweet as close as possible to the mid to keep the imaging stable. I'll play around with it. How about the subs? Which way do you guys fire them, up, down, or straight? I'll be using 8s so I think it can fire them forward. Where in Cali are you Smoke?
2005 Mercedes C-Class
SOLD
2005
Smoke SE Crew Cab
Modifications: a few mods.....
More Pics Here
m95roadster is offline   Reply With Quote
