Thread: Pie Amp?
Old 03-19-2005, 05:05 PM   #4 (permalink)
Sammy Sandbag
Sammy Sandbag's Avatar
Originally Posted by radsterrad
How Did You Wire This Into The Grounding Circuit?
A ground loop isolator installs in the signal lines (RCA's.) Where did you ground your PIE at? Also, what 12V source are you using, the cig plugs? I notice a little alternator noise during quiet songs and high volume, but I've pretty much determined mine is from a bad mini connector. I haven't got around to troubleshooting/fixing it because I'm in the middle of a complete audio overhaul.
-Counsel Yourself
2009 Blizzard Pro-4X
