find the headlight wire and add a 5-terminal relay. when the headlights are turned on, it triggers the relay and feeds power to your fogs.
the headlight wire will be connected to terminals 85 and 86. choose one and then ground the other. feed power to terminal 30. attached the positive lead from the fog to terminal 87. leave 87a disconnected.
