Old 03-20-2005, 06:04 PM   #1 (permalink)
Squid
Banned
Squid's Avatar
Solutions to Known Problems.
This an attempt to consolidate all the known solutions to problems in one place. If you know of, or run across a thread not listed on this first post let me know and I'll edit this post accordingly with the link to the thread. This should after a while help out not only the new owners/members but also the long time members with bad memories.
REMEMBER KEYWORD, Solutions.
Audio.
1.)Aftermarket Stereo Installation Knowledge Base.
(Suggested by Bestatchess, Contributed by Boucoup Audio Gurus )
Installing Aftermarket Radio Tonight...
2.) Audio Install with Pics.
(Contibuted by M95roadster)
Audio Install...the beginning w/Pics
3.) Bezel/faceplate and door panel removal.
(Contributed by Bestatchess Post #4)
Stereo installation
4.) Low Audio level through Aux Input Solution.
(Contributed by Sammy Sandbag)
Hardwired MP3 Player
5.) Airhorn for the Titan.
(Contributed by Juma post #6)
http://www.titantalk.com/forums/show...361#post329361
Brakes.
1.) Brake Recall Info. Warrenty extension document for 04/05 brakes.
(Contributed By Slurppie)
Brake Recall Info
2.) Stillen aftermarket Big Brake Kit.
(Contributed by gr8titan )
They're here: Stillen Big Brakes
Cab
1.) Microfilter replacement/Installation (Great How To, for trucks with no filter from the factory. All trucks do have the filter Box)
( Contributed by VW1972bugs post #21)
Microfilter- King Cab
2.) Check Engine Light, toolless code retrieval.
(Contributed by Titanparts1 post #16)
Service Engine Soon Light
3.) Low Tire Pressure Warning System FAQ.
(Contributed by Austin Post#14 and others.)
Low Tire Pressure Indicator
4.) Popping sound when closing the door.
(Contributed by HavockWK and Friends. Post #4 of this thread.)
5.) Windows creaking in the up position.
(Suggested/Solution by ctuck13 post # 12 of TITANTALK link, Solution by adjmcloon Post #6 and #10 of CLUBARMADA link)
drivers side faint rattle
http://www.clubarmada.com/showthread.php?t=465
6.) Air bag sensor light reset procedure.
(Suggested by Sammy Sandbag, Solution by smoketitan)
Dash Air Bag Sensor Reset
7.) Keyfob ID setup
(Suggested by BLwedge09)
http://www.titantalk.com/forums/atta...achmentid=9665
Differentials .
1.) Photos of 05 aluminum rear diff cover install/Info.
(Contributed by gr8titan)
Photos of 05 aluminum diff cover install
2.) Low differential fluid discovery.
(Contributed by JETTECH)
Everyone PLEASE READ!!!
3.) Checking/Draining the Front Differential.
(Contributed by BigJoe Titan, Post #32)
Differential lube check screw-locktite??
4.) Checking/draining the rear Differential.
(Contributed by Bestatchess Post 2# and #4)
Rear Diff fluid question...HELP!!
5.) Differential drain plug torque/sealant.
(Contributed by Bayou Titan Post #2 and Bestatchess Post#3)
Checking Rear Differential
6.) Rear Differential fluid change Pictures.
(Contributed by Admorris)
Rear diff. fluid change pics
7.) E-Lock locked in 2WD, 4HI & 4LO Modification
( Contributed by Austin)
Electrical
1.) Optima battery and grounding upgrade.
(Contributed by 1BADTITAN)
Pic of my Optima Battery and Grounding Set
2.) Wire colors and purpose
(Contributed by Wareagle)
http://www.titantalk.com/forums/show...272#post328272
3.) Wiring 101 for dummies.
(Contributed by Bestatchess and Juma)
Hard Wire Help
Engine.
1.) How to:ECU Reset,Throttle & Accelerator Position Learning
(Contributed by ROCKYMTNTITAN)
http://www.titantalk.com/forums/show...027#post316027
2.)Nissan Titan V8 engine development SAE white paper.(VK56DE INFO)
(Contributed by ARMADA)
http://www.titantalk.com/forums/atta...tid=9430&stc=1
3.) Oil Analysis.
(Contributed by JetTech)
Titan loves Mobil 1 0W-40
4.) Oil Pressure Fluctuation as seen on the gauge.
(Contributed by BLWEDGE09, Post#2)
Oil pressure guage
5.) Air Conditioning Drain Tube Extension.
(Suggested by Cajunguy, Contributed by Vshortt, Instructions by 37L1 Post #60 and Friends)
Another Water Problem
6.) Blackstone labs (oil Analysis) $20,00
http://www.blackstone-labs.com/
Free Kit form.
http://www.blackstone-labs.com/free_test_kit.html
Exterior Safety Items
1.) Windshield wiper skipping/replacement blades
(Contributed by everyone in the following threads.)
wipers squeaking and skipping
windshield wipers
Noisy Windshield Wipers
2.) Removal/ Installation of Big Tow Mirrors
(Contributed by BigRedTitan)
Big Tow mirror problem
3.) Oily film on windshield removal.
(Contributed by all involved)
Oily film on windshield.
4.) Changing wheels/Tire rotation/Lug nut Torque.
(Suggested by Wrenrj1)
http://www.titantalk.com/forums/atta...achmentid=9666
5.) Spare tire remote air up/check Mod.
(Contributed by RDfeatherstone)
Valve Extension Hose?
Lighting
1.) Replacment procedure for Headlights/turn signals/parking/sidemarker.
(Contributed by RRUMANER Post #9)
Bulb Size
2.) Headlight Adjustment.
(Contributed by Stitch)
Check Your Aim
3.) Solution for inadvertant shutting off of headlights.
(Contributed by honeykeeper, solution by carpentry1@optonline)
Cure for accidentally turning off lights 63¢!
4.) Solution for Intermittent dash/enviromental control knobs lighting.
(Suggested by Fluxcubby, solution by me post#3)
Electrical Gremlins
Service.
1.) Service Department Advice.
(Contributed by Wrenrj1 )
Dealing with Dealer Service Depts.
2.) Downloadable Service Manual FAQ.
(Suggested by Bestatchess, Contributed By Many.)
Downloadable Service Manual Question
3.) Nissan Free Downloadable Owners Manual(Contributed by me)
http://www.nissan-techinfo.com/nissa...id=&dept_id=30
4.) TSB Website
(Contributed by me.)
http://www.nissanhelp.com/Bulletins/Model.htm
5.) TSB's (in .PDF format)
(Contributed by Z23Fan)
Suspension
1.) Axle Wrap. (Explanation and Solution)
http://www.titantalk.com/forums/show...6&postcount=31
2.) Squeaky Suspension.
(Contributed by Mike H Post #18)
Squeaky suspension
Ticks/Rattles/Bumps
1.) Fix for tick on passenger side area.
(Contributed by arkman0, Post#7)
Fix for tick on passenger side area?
2.) Bump sound from bed when slowing to a stop.
(Suggested by Optimist, Member who first found solution unknown)
THings that go bump in the night......(problem)
Tansmission
1.) Transmission fluid change.
(Contributed by Juma)
sunday transmission fluid change - the easy juma way
Towing
1.) Towing FAQ.
http://www.titantalk.com/forums/show...061#post279061
2.) Trailer light relay P/N and Installation.
(Contributed by KYdeepwater and Pagerdaddy)
Trailer Wiring
3.) 4X4 drop hitch drop length discussion.
4X4 drop hitch "drop" length????
Squid is offline   Reply With Quote
The Following User Says Thank You to Squid For This Useful Post:
Roodogg (06-24-2009)
