Old 03-30-2005, 10:34 AM   #6 (permalink)
smoketitan
smoketitan's Avatar
Originally Posted by sammy sandbag
I also ran new wires, including two sets of wires through the back door rubber boots for both the tweeters and woofers. The front was a bit harder just because you don't have as much access to the boot. I also removed the glove box to make it easier to get to the right front, I'm not sure it's possible to do it without removing it.
why did you take out the glove box??? I didnt have to do that?
I also ran my own wiring (14-16 ga) after first using the stock wires
anything over 50wrms---run your own wire
the stock wire is only 20-22ga VERY thin
