Old 03-31-2005, 05:39 PM   #13 (permalink)
MaxPowers
Send a message via AIM to MaxPowers
Originally Posted by phoenix titan
by the time you pay for the lift and body lift and install on 2 kits your with in 100-200 bucks of the cost so y not go big? sure your tires and shocks are going to be a bit moor but if you are like me and use your head and buy parts 1 at a time and do some foot work you will save $$ and not have to settle for some thing that you wished you had spent a extra 100.00 bucks for think about it cst 8' lift 2,200.00 performance body lift 379.00 install 2 kits 800.00 bulitproof 12' kit 3,100.00 + 400.00 intall just in the kit and install you are spending extra $121.00 big woop in the grand skeem of things! and you still can go bigger if you want. nuts but hay you can!!!
Actually, it is a lot more expensive than you think. This is a quote from a post that was made awhile ago about the cost of the bulletproof lift, rather expensive!!
"I just came from SoCal Supertrucks, and sure enough they have a 12" suspension lift for the Titan made by Bullet Proof Suspension. I can can tell you that this is one massive looking lift kit, they in fact were installing one on a Titan. The components are equal to what CST makes. I must say that the truck they had there was looking pretty good. In fact it was a brand new Black Crew Cab 4x4 Titan that was being lifted for the Nissan dealership in Hemet. Currently this truck was running 20" wheels with 38" tires and a B-Cool Billet Grill. Also there were in the process of making a custom from light bar made w/ 4 Hella lights.
I feel that cost is going to be a down-fall for this lift. First, you must use coil-over front shocks which are not cheap in the first place. Second, the kit is very basic, you still have to purchase new rear leaf springs to complete the lift.
Here's the run down from SOCal:
Bullet Proof 12" Suspension Kit - $3650.00
Atalas 9" Rear Leaf Springs - $675.00
2 Fox 12" 2.5 coil-over shocks w/ res. - $1450.00
2 Fox 2.0 shocks w/ res. - $370.00
SoCal Labor - $1000.00
High Angle "CV" Rear Drive Shaft - $495.00
Total Cost w/ Tax: $8116.24
Was told they would do the package for $7750.00 out the door
SoCal Supertrucks: 909-383-5454"
MaxPowers is offline   Reply With Quote
