Thread: Tow ratings
Old 04-13-2005, 10:47 PM   #12 (permalink)
Mike Up
Banned
Originally Posted by ptgarcia
Just an FYI:
When speaking of gear ratios, numerically higher numbers are referred to as a lower gear ratio. So the 3.36:1 gears are lower than the 2.95:1 gears.
No, the rear end is a higher ratio, the numbers speak. However the gears are shorter. You can either refer to it has a higher ratio or a shorter gear.
Have a good one.
Mike Up is offline   Reply With Quote
