Steamguy,
Thanks for the info. At this time I don't have a sway control setup, or any setup for that matter. I will be buying everything at once. I am looking at the Reese setup myself. You can bet I will be buying the best.
I'm not sure if you realise the trailer is only 29', with the additional 3' of tongue, and only weighs 6500-lbs. It sounds similar to what you are pulling, albeit 2' longer. I'm not "stuck" on this trailer at all, but am considering it. My likely 1st choice is a 27' (30' from ball to bumper) with 5975 UVW. By the way, both trailers are Aljo by Skyline. I wanted to consult with someone such as yourself before placing my order.
Pauly
