Old 04-18-2005, 08:03 AM   #6 (permalink)
92TripleBlack
92TripleBlack's Avatar
Originally Posted by 54warrior
Yeah, i know exactly what you mean. I plan on ordering the PRG leveling kit this week, to gain clearance. I too like the looks of the Toyo Open Country A/T in this size:: LT325/60R18. it says that it will be around a 33.6 OD. Anyone know where to get a price on these?
Mine are basically the same as the Toyos, but with lightning bolts on the sides. $250+/- a tire. The outer diameter isn't going to be what gets you, it will be the width. You won't rub with the tires centered or at full turn. However, at half turn the tires are going to rub like crazy the inside of the tire wells. Mine rubbed and are about 1" more narrow and same outer diameter. THey even rubbed on the grey piece that is the trim for the sidestep. I had to use a heat gun and warp the plastic as much as possible to make mine fit. You'll probably have to cut some out to get yours to fit. I looked at those and considered them before buying the ones I have now. If they made them in a 305/65 I would have gotten them but I couldn't find an A/T in the right size for an 18" wheel. The 17" guys have the 295 and that's a good fit. Hope this helps.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
