Axle wrap according to Fabtech
I don't if this helps but, I asked Fabtech this problem today and they said that it's mostly a problem with 4x2's. The culprit is the angle of the the driveline after a lift. You can get a kit to lower the transfer case to solve the vibration and floating traction bar for the axle wrap or helper springs (just make sure you install it on the front of the spring towards the front of the truck).
nxf
