Old 04-26-2005, 08:37 AM   #6 (permalink)
Skip102
Thanks.
Originally Posted by rcantu
welcome to TT.
you did a good job. I've seen and heard of so called "professionals" that do something not as close as you've done. I'm working on putting 6.2" headrest in mine so I'm going to do some cutting too. Now I'm not as worried.
Thanks for the kind words guys.
rcantu... you may already know that with the Titan headrests there is no mounting plate only the headrest support bar that makes a loop through the block of foam which makes mounting the headrest tricky. Others have used plastic ties through the monitor's mounting holes and around the bar.
The secret is lots of test fitting as your cutting!
Skip102 is offline   Reply With Quote
