I have a clunk at very slow speeds (less than 5mph) that i thought was comming from the front. After closer inspection i found it is comming from the rear leaf springs. If you shake the truck side to side very hard you can hear the noise. The noise is comming from the front bolt that connects the leaf spring to the frame.
I have not seen any posts on this but i am going to take mine back to the dealer to have them check this out.
Steve
