Originally Posted by Bear Hunter
Thats not axle wrap. It is driveline shudder from incorrect angle of the driveshaft. Carrier bearing shim kit, reindexing the X-Fer case, or a CV rear driveshaft can fix that problem.
Axle wrap feels like the rear end of your truck is standing up when accelerating hard...then it will go back down....it has nothing to do with vibration...that is coming from your driveline.
I don't know what your carrier bearings look like, but on SD's its a simple shim kit with shims that are different thicknesses that you stack to get the correct angle.
Can someone post a pic of the Nissan Carrier bearing and this kit you have?
here are some sorry if you can't see to well, crawling under there in the dark and taking them didn't turn out so well.
