Old 05-05-2005, 05:56 AM   #9 (permalink)
cttitan
cttitan's Avatar
Originally Posted by HudsonValleyTitan
This months R&T has an article in its' TECHNICAL CORRESPONDENCE that says it all. A reader writes in that he heard that his 04 Accord will have a 10HP boost if he used premium fuel, and wanted to know if this was just a "pipe dream". The vehicle can be any newer vehicle using a knock sensor according to the article. Here's their answer:
""This one is for real. Modern electronics is good enough that automakers are now writing engine-management software to "follow the knock sensor." That is, the ignition timing, which is already being adjusted by the engine management computer many times per second, is largely determined from what the knock sensor is commanding.
In practice, this means the computer is often advancing the ignition timing (for better power and fuel economy), while the knock sensor announces when the timing is too far advanced whenever knock is detected. Then the computer retards the timing a couple of degrees and the process repeats. Everything else being equal, the higher the fuel octane, the more ignition timing can be run before knock occurs, and thus more power is made. Because the system is constantly at work and finely adjustable, it accounts for the various fuel blends that end up in the cars tank.""
But some of us already knew the benefits of using premium.
But our knock sensors do not normally retard the timing according to the service manual...
This is what the service manual has to say about the knock sensors in the Titan.
The knock sensor retard system is designed only for emergencies. The basic ignition timing is programmed within the anti-knocking zone, if recommended fuel is used under dry conditions. The retard system does not operate under normal driving conditions. If engine knocking occurs, the knock sensor monitors the condition. The signal is transmitted to the ECM. The ECM retards the ignition timing to eliminate the knocking condition.
Silver 4x4 SE CC, Born 3/04
Graphite Titanium
Off Road/No Locker, BIG TOW/VDC
Step Rails, Truxedo,
Gibson Cat Back, AEM Brute Force CAI
Hood Protector, Tinted Windows
My other car is a diesel
(02 VW Jetta TDI, 49 MPG)
Rockwood 2306 Travel Trailer
Equalizer Hitch, Prodigy Controller
cttitan is offline   Reply With Quote
