Old 05-12-2005, 10:22 AM   #2 (permalink)
92TripleBlack
92TripleBlack's Avatar
The outer diameter max would be 33.5" and the width would be 305. If you go wider, you will need flares or mud will be hitting your doors. If you go wider or taller, you will be scraping. My combo maxes out what you can do but there are other combos that do the same: 295-70-17 for example is a good one. 285-65-18 is also if you can find one and so on. This is for stock. If you put a level kit on, you can go 1-1.5" taller. Wider will still give you the spatter problems.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
