My tires are just strange....I have a very odd feathering pattern going on. My tires are at 38psi (technically overinflated) and yet the outside edges of my front tires are feathering front - back. If you run your hand along the siping on the outside edges for any particular block, the leading edge is lower and the upper one sticks up. When rotated to the back it goes away for the most part.
Nissan contends that this is normal wear for a truck, but I have yet to see anyone else with the wear.
Since other people are having varied problems too, I would say the problem is the Tire and not the truck. When I went to a Goodyear store they told me made these tires just for the Titan. I don't know how much research was done on them and such and that may be a factor. According to tirerack there are Continental tires in our size, or you could check out maybe a slightly wider tire since there are probably more of those out there.
Good luck.
1.
