Old 05-21-2005, 08:01 AM   #3 (permalink)
37L1
37L1's Avatar
Originally Posted by bigdawg1
Purchased a Volant air intake system for 2005 Titan off road truck. The info on the kit says 20 minutes to install. After 1.5 hours of trying to get the hole in the filter box to match up with the stock stud hole on the fender well, I gave up. I tried everything to get the kit bolt in the threaded hole. If I could have made that connection, then the rest of the installation would been a piece of cake. Also, do the two tubes coming off of the volant air flow duct replace all the stock stuff? Is there anyone out there that can help or that has directions to install this 20 minute kit? thanks
It's a simple process and it only took me 20 minutes, everything matched up.
I lined up the box vent with the fender well and then put the mounting bolt into the hole at the bottom of the box, you may want to use the OEM bolt from your stock box, that should help you a little bit.
Here's a post that gives you install instructions straight from Joe at Volant:
http://www.titantalk.com/forums/show...907#post178907
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
