Old 05-22-2005, 11:25 PM   #6 (permalink)
bestatchess
Originally Posted by Davegvg
About 800 bones for the rotors / metal matrix pads/ and SS lines.
You can find them on the stillen website- then a few hundred to throw them in and bleed the system. (which is a pain)
(dont short chnge yourself on any one thing, either do it all or wait)
Davegvg
04 Titan CC le 4X4 big tow/ Stillen OEM brakes/ ss lines
95 Maxima Stillen blower/brakes
21ft Laveycraft sebring tunnel (406 small block 100+ mph)
2 Yamaha banshee stage3/4
Cr-500
24ft weekend warrior
2 segway human transporter
1 96 BMW Z3 (wife car hate it)
Kalamaoo BB4 dual fuel SS grill
I just finished installing the stillen OEM rotors & metal matrix pads. I already had SS lines & DOT 4 fluid. It is not that hard to install although you need to remove a couple of 21 mm bolts to remove the pad holder to get the front rotor off. If you don't have air tools, better eat your wheaties as Nissan didn't spare the thread lock. Bleeding is pretty easy with speedbleeders.
JetTech posted some great instructions & photos on changing pads at clubtitan.org. With new rotors, you don't need to do the glaze breaking step, but you do need to get the protective coat of oil off the new rotors with brake cleaner or maybe alcohol would also work. My other tip is make sure you get the rotors on the correct side of the truck as the cross-drilled hole patterns are directional.
They seem good to me so far.
