Thread: Running Boards
Old 05-27-2005, 05:26 AM   #2 (permalink)
travism
travism's Avatar
Send a message via AIM to travism Send a message via Yahoo to travism
If you get the OEM ones then it is very easy, although it is easier if you have a helper to hold the rail in place while you tighten the bolts. On my king cab there are 3 posts on each side that it hangs on, then another 3 bolt holes in the frame that bolts will go into after going through the brackets on the rails. All mounting hardware should come with the rails. I'm sure you have the 3 (or maybe 4 on a crew cab) posts and bolt holes and are just not looking in the right places yet.
Most aftermarket ones that are made specifically for the Titan will have brackets that line up with the holes that are already on your Titan. So it should be just as easy. No need to pay someone in my opinion. But it will be much easier if you have a set of deep metric sockets to put the nuts on the posts.
If you like the looks of them, the OEM ones are sturdy and holding up fine for me.
'04 Titan SE King Cab 2WD Deep Water
Popular Pkg w/ Captains, Big Tow
Added: OEM step rails & splash guards, leaf spring helpers, Line-X, TruXedo LoPro tonneau, Wade In-channel window visors
Born 6/3/04, Bought 7/5/04
travism is offline   Reply With Quote
