Old 05-27-2005, 10:47 AM   #183 (permalink)
Oldfordowner
Originally Posted by talltom
If you put a thicker rotor on you are going to need a wider caliper to make it all work, unless you use a thinner brake pad. Somebody who had the "final" fix needs to post the parts list.
The new rotor is not thicker, the material on the inner and outer solid portions are thicker and the vanes are thinner. The rotor fits the existing calipers.
Pictures were posted several days ago showing the difference.
Oldfordowner is offline   Reply With Quote
