Found the perfect spot to put a switch or two..or audio jack
I'm almost to the install phase of putting a PC in the mada to compliment the navi/avelectronic box I already have and was looking for where I was going to put the misc switches/usb/firewire ports. I found the perfect place! I can't believe I hadn't thought of before.
There is that little swing out arm on the front of the center console in the little bin between the shifter and console to hold a large cup...if the bin is ever empty enough to put something in it.. If you swing out that arm there is a nice little cubby behind it that you could put a switch or two easily and be stealthy. The spot would be perfect to relocate a mini jack to and wire it into the AUX jack for those who use the AUX for a Ipod etc and not have wires running across the dash. Just thought I'd pass it along to others who may not of thought about this spot.
The shallow end of the gene pool needs some chlorine!
April 04 Armada
Mods: 20% tint, Blaupunkt ME3 TV/DVD player wired into factory dvd wiring (read how to here) , 7" monitor (see it here), video on Navigation screen (how to here) , reverse camera, hood deflector, weathertech vent visors, sunroof deflector, Cascade sound deadener, Street Scene Grille and a fully functioning car-mada-puter, Download fauxdynoV3.0.xls
