Originally Posted by Vector
When you added your own amps to the system, did you use a converter to go from the high level speaker outputs of your factory head unit to RCA's on your aftermarket amps? If so what did you use to down vert the signal? I have auxilliary inputs on my other head unit, so I could put the factory system in to it that way, but would need to find a really nice high level output to low level converter. Any suggestions?
Thanks!
The speaker outs from the RF head unit (before they go to the RF amp) are way way low.
I am using the navone 4-channel LOC:
http://www.davidnavone.com/adaptor_products.htm
and then to the Audio Control Matrix:
http://www.mobileaudiocontrol.com/de...d=5249&l1=5249
which amps front/rear/AUX jack (front/rear goes from Matrix to amps; amplified AUX jack goes to RF head unit)
another possibility is the UI-4 from
www.altomobile.com if they ever manage to get it produced:
http://www.altomobile.com/html/accessories.html
I'm not seeing any way to ditch the RF head unit & maintain integration with NAV & DVD. Mine is now pretty livable, since I never listen to AM or FM. Probably one of the new MP3 players with built-in FM tuner plugged into the AUX jack would be better than my RF head unit's FM reception.
Be sure to post if you figure something out.
