Old 06-06-2005, 02:34 PM   #7 (permalink)
eakes
Look carefully at the plug on your cable and the headset you are using on the player. If it is stereo the tip will be followed by a band of color (usually black) the next 1/8 inch or so will be silver then another band of color then more silver. If it is mono there will be a tip then a band of color then more silver all the way to the 'handle'. For stereo the connections are designated as tip, ring and sleeve (ring is the section of silver material between the two bands of color). Tip and ring are for the two stereo channels with the sleeve being the shield return.
