I got another reply from AJ:
Originally Posted by AJ Eschwig
We are not Power Point users, so not sure if I can be of any help.
Basically we need a vector graphics file which has actual lines and curves
making up the graphic so the machines know where to do the cut lines.
If I remember right, there is a way to export to eps from PP, you might check.
If not, then we would have to recreate the file in the proper format, which
would be a $20 charge. When you send the file maybe let us know what fonts
you used and we can just recreate it to match.
I looked all through Power Point, and I can't export to the necessary file type. My version of Adobe Illustrator doesn't work either, so I can't make it as an AI file.
I'm thinking we just get this guy to make the final design and run it by us. All we need to give him is the layout, size, and logos we want to use.
I'm guessing he can also find a better font that will better match Nissan's TITAN & SE letters. Considering how cheap the stickers will cost, I dont think $20 is that much to ask, unless someone here can it it better for free.
Now the final questions. Do we want the logo to look like the following:
(Texas Shape = Size of TNT-SE and white Bar)
Or the original design:
(Texas Shape is a little bigger)
And finally another idea incorporating Nissan's "SHIFT_" theme:
Here is the Nissan font that the logo should mimic:
