The issue is the passenger airbag light in the center console. Even though it can be disconnected without impacting other SRS components, once the circuit breaks, an error code gets stored.
The "reset" process puts the SRS system into diagnosis mode, upon which if the light has been reconnected, no error code would trigger (no need for the warning light).
Hope this explains what happened. Helpful advice for those that are putting aftermarket equipment in the center console.
FWIW - isn't it a PITA to have to remove the entire bottom half of the dash just to get the center console portion with the vents off???
