Originally Posted by sts7049
to add to that, it's easy if you crank the wheels so you have more room to reach. you can see them right there with the wheel turned.
And there is 1 phillips head screw that holds the fender liner in place. After you crank the wheel over, remove that screw to get easy access to the headlamps.
