Originally Posted by sbo76
They will fit, but they will sound like crap. The stock HU only pushed about 6-10 watts per channel (this is being generous). If you don't like that much bass or listen to them loud, I would just add a set of tweeters in the dash and call it a day. The stock system is bad, but for your criteria, a decent set of tweeters would suffice. Given the power from the HU, the stock speakers will outperform the Infinities.
Scott
Thanks for the tip. New tweeters to replace the stock ones would be an inexpensive upgrade, right? Are the OEM ones a standard size (i.e., easy to match)?
