Old 06-12-2005, 11:11 PM   #1 (permalink)
drpeeb
drpeeb's Avatar
Questions re: Fog lights on an SE ...
I got the KC SE this weekend and want to get the exact fog lights that come on the LE's. Some questions:
Can I get either factory fog lights or is there an aftermarket set that looks essentially identical? I want them to look stock.
I've never turned on the factory fog lights in an LE, but it looks like the switch is located in the turn signal stalk - True? If so, if I install aftermarket fogs, will I use that same switch location or do you normally mount it on the dash somewhere?
Thanks!
drpeeb is offline   Reply With Quote
