Fill the plastic sub box under the driver's seat with polyfill from Wal-Mart: $2.00.
If you have OEM NAV or DVD, the loss of integration when replacing the OEM RF head unit should be considered. You can buy an XE double-din bezel and use a double-din head unit. Steering wheel control integration can be retained with a PAC switch unit.
The OEM RF amp is inadequate to power most decent aftermarket speakers. The OEM speakers are 2 ohm.
