I think you need some wires, yeah. My understanding is that a Bazooka Tube has an amplifier and a subwoofer. Assuming it has a decent amp, you would need power wires and a fuse to power the amp. One power wire would need to run to the battery positive terminal under the hood, so it would be fairly long and a fairly big diameter wire. Then you would need to get a signal from the head unit to the Bazooka. Assuming the Bazooka has RCA inputs, this might require a 2 channel LOC and some RCA cables. Depending on what is in the wiring kit, $100 might be reasonable. I would ask for an itemized list of exactly what comes with the wiring kit.
P.S. Some amps also need a remote turn on wire, which is not an expensive item. Some RCA cables include a remote turn on wire.
