All newer sets, the good ones at least, have multiple mounting options. Your new ones should be able to flush mount like my Polks and they fit no problem. About the black clips.....take a flat head screwdriver and pry up on one corner of the factory tweeter plate (be sure to place a rag between the plastic dash and the screwdriver). Once you work one of the corners up you should be able to, with a little convincing, be able to pull it out. I did both of mine and I don't remember having much trouble pulling out the junk.
