Old 06-22-2005, 06:33 AM   #33 (permalink)
Clancy
Clancy's Avatar
Originally Posted by Squid
This an attempt to consolidate all the known solutions to problems in one place. If you know of, or run across a thread not listed on this first post let me know and I'll edit this post accordingly with the link to the thread. This should after a while help out not only the new owners/members but also the long time members with bad memories.
REMEMBER KEYWORD, Solutions.
Audio.
1.)Aftermarket Stereo Installation Knowledge Base.
(Suggested by Bestatchess, Contributed by Boucoup Audio Gurus )
Installing Aftermarket Radio Tonight...
2.) Audio Install with Pics.
(Contibuted by M95roadster)
Audio Install...the beginning w/Pics
3.) Bezel/faceplate and door panel removal.
(Contributed by Bestatchess Post #4)
Stereo installation
4.) Low Audio level through Aux Input Solution.
(Contributed by Sammy Sandbag)
Hardwired MP3 Player
5.) Airhorn for the Titan.
(Contributed by Juma post #6)
http://www.titantalk.com/forums/show...361#post329361
Brakes.
1.) Brake Recall Info. Warrenty extension document for 04/05 brakes.
(Contributed By Slurppie)
Brake Recall Info
2.) Stillen aftermarket Big Brake Kit.
(Contributed by gr8titan )
They're here: Stillen Big Brakes
Cab
1.) Microfilter replacement/Installation (Great How To, for trucks with no filter from the factory. All trucks do have the filter Box)
( Contributed by VW1972bugs post #21)
Microfilter- King Cab
2.) Check Engine Light, toolless code retrieval.
(Contributed by Titanparts1 post #16)
Service Engine Soon Light
3.) Low Tire Pressure Warning System FAQ.
(Contributed by Austin Post#14 and others.)
Low Tire Pressure Indicator
4.) Popping sound when closing the door.
(Contributed by HavockWK and Friends. Post #4 of this thread.)
5.) Windows creaking in the up position.
(Suggested/Solution by ctuck13 post # 12 of TITANTALK link, Solution by adjmcloon Post #6 and #10 of CLUBARMADA link)
drivers side faint rattle
http://www.clubarmada.com/showthread.php?t=465
6.) Air bag sensor light reset procedure.
(Suggested by Sammy Sandbag, Solution by smoketitan)
Dash Air Bag Sensor Reset
7.) Keyfob ID setup
(Suggested by BLwedge09)
http://www.titantalk.com/forums/atta...achmentid=9665
Differentials .
1.) Photos of 05 aluminum rear diff cover install/Info.
(Contributed by gr8titan)
Photos of 05 aluminum diff cover install
2.) Low differential fluid discovery.
(Contributed by JETTECH)
Everyone PLEASE READ!!!
3.) Checking/Draining the Front Differential.
(Contributed by BigJoe Titan, Post #32)
Differential lube check screw-locktite??
4.) Checking/draining the rear Differential.
(Contributed by Bestatchess Post 2# and #4)
Rear Diff fluid question...HELP!!
5.) Differential drain plug torque/sealant.
(Contributed by Bayou Titan Post #2 and Bestatchess Post#3)
Checking Rear Differential
6.) Rear Differential fluid change Pictures.
(Contributed by Admorris)
Rear diff. fluid change pics
7.) E-Lock locked in 2WD, 4HI & 4LO Modification
( Contributed by Austin)
Electrical
1.) Optima battery and grounding upgrade.
(Contributed by 1BADTITAN)
Pic of my Optima Battery and Grounding Set
2.) Wire colors and purpose
(Contributed by Wareagle)
http://www.titantalk.com/forums/show...272#post328272
3.) Wiring 101 for dummies.
(Contributed by Bestatchess and Juma)
Hard Wire Help
Engine.
1.) How to:ECU Reset,Throttle & Accelerator Position Learning
(Contributed by ROCKYMTNTITAN)
http://www.titantalk.com/forums/show...027#post316027
2.)Nissan Titan V8 engine development SAE white paper.(VK56DE INFO)
(Contributed by ARMADA)
http://www.titantalk.com/forums/atta...tid=9430&stc=1
3.) Oil Analysis.
(Contributed by JetTech)
Titan loves Mobil 1 0W-40
4.) Oil Pressure Fluctuation as seen on the gauge.
(Contributed by BLWEDGE09, Post#2)
Oil pressure guage
5.) Air Conditioning Drain Tube Extension.
(Suggested by Cajunguy, Contributed by Vshortt, Instructions by 37L1 Post #60 and Friends)
Another Water Problem
6.) Blackstone labs (oil Analysis) $20,00
http://www.blackstone-labs.com/
Free Kit form.
http://www.blackstone-labs.com/free_test_kit.html
Exterior Safety Items
1.) Windshield wiper skipping/replacement blades
(Contributed by everyone in the following threads.)
wipers squeaking and skipping
windshield wipers
Noisy Windshield Wipers
2.) Removal/ Installation of Big Tow Mirrors
(Contributed by BigRedTitan)
Big Tow mirror problem
3.) Oily film on windshield removal.
(Contributed by all involved)
Oily film on windshield.
4.) Changing wheels/Tire rotation/Lug nut Torque.
(Suggested by Wrenrj1)
http://www.titantalk.com/forums/atta...achmentid=9666
5.) Spare tire remote air up/check Mod.
(Contributed by RDfeatherstone)
Valve Extension Hose?
Lighting
1.) Replacment procedure for Headlights/turn signals/parking/sidemarker.
(Contributed by RRUMANER Post #9)
Bulb Size
2.) Headlight Adjustment.
(Contributed by Stitch)
Check Your Aim
3.) Solution for inadvertant shutting off of headlights.
(Contributed by honeykeeper, solution by carpentry1@optonline)
Cure for accidentally turning off lights 63¢!
4.) Solution for Intermittent dash/enviromental control knobs lighting.
(Suggested by Fluxcubby, solution by me post#3)
Electrical Gremlins
Service.
1.) Service Department Advice.
(Contributed by Wrenrj1 )
Dealing with Dealer Service Depts.
2.) Downloadable Service Manual FAQ.
(Suggested by Bestatchess, Contributed By Many.)
Downloadable Service Manual Question
3.) Nissan Free Downloadable Owners Manual(Contributed by me)
http://www.nissan-techinfo.com/nissa...id=&dept_id=30
4.) TSB Website
(Contributed by me.)
http://www.nissanhelp.com/Bulletins/Model.htm
5.) TSB's (in .PDF format)
(Contributed by Z23Fan)
Suspension
1.) Axle Wrap. (Explanation and Solution)
http://www.titantalk.com/forums/show...6&postcount=31
2.) Squeaky Suspension.
(Contributed by Mike H Post #18)
Squeaky suspension
Ticks/Rattles/Bumps
1.) Fix for tick on passenger side area.
(Contributed by arkman0, Post#7)
Fix for tick on passenger side area?
2.) Bump sound from bed when slowing to a stop.
(Suggested by Optimist, Member who first found solution unknown)
THings that go bump in the night......(problem)
Tansmission
1.) Transmission fluid change.
(Contributed by Juma)
sunday transmission fluid change - the easy juma way
Towing
1.) Towing FAQ.
http://www.titantalk.com/forums/show...061#post279061
2.) Trailer light relay P/N and Installation.
(Contributed by KYdeepwater and Pagerdaddy)
Trailer Wiring
3.) 4X4 drop hitch drop length discussion.
4X4 drop hitch "drop" length????
This is a worthwhile and very valuable post - if it's not already, it should be a sticky! (Opps - I see it is. Nevermind!)
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
Clancy is offline   Reply With Quote
