Thread: PIE LD-1 Wiring
Old 06-29-2005, 07:52 AM   #8 (permalink)
tyler2you
It's mounted in the tray where the DVD nav would be if I had that option. I drilled a hole under the rubber mat and you can't even see the cable. I'll post a pic later.
BTW--how's the sound quality on your Commander? Do you get some "crackling" at higher volume? When I'm playing my Ipod through the Belkin Auto Kit, it sounds great. I may experiment with moving the ground connection to another location to see if that helps.
tyler2you is offline   Reply With Quote
