Old 07-02-2005, 08:25 AM   #15 (permalink)
wmtom
Banned
wmtom's Avatar
Originally Posted by pciley
I think this the appropriate section to post this question.
The Titan's diff is not a big deal to fill, even though the angle is pretty bad for squirting from a quart bottle, but my Jeep and Astro van are a B!TCH to get the fluid in.
Does anyone know where to find a powered fluid pump?
I tried one of the manual ones from Auto Zone that thread on to the quart bottles, but it took about 1213214234 pumps to get all the fluid in and I won't be able to masturbate for a week
The manual pump is useless.
The only power one I found on JCWhitney.com required a 12-volt battery, used alligator clips. No good for reaching rear end, cords not long enough.
Isn't there something that uses batteries, or 120 volt, that is "affordable?"
PS. I tried a search and found only what I had already used and didn't like.
if you happen to have the power outlet in the titan bed or for the other cars cut off those ali. clips and put on a lighter plug, lengthen the wire as needed
wmtom is offline   Reply With Quote
