Thread: A/C smells sour
Old 07-28-2005, 02:38 PM   #2 (permalink)
DeeDubya
DeeDubya's Avatar
The A/C evaporator coil has a pan under it that catches water and directs it out a drain. After driving with the A/C on check the water that's dripping under your truck. This is condensate from the A/C. If it smells sour then you know where the smell is coming from. If it's not dripping then you have bigger problems, the drain is clogged.
Also, you might check the micro-filter. A new clean filter might help.
DW
2005 Titan 4x2 LE CC
22x9.5 Eagle Alloys Series 170
305/45R22 Falken Ziex
Stillen Brake Pros Big Brakes
A.R.E. Tonneau
Precision Billet Grills
Banks Monster Exhaust
DeeDubya is offline   Reply With Quote
