Old 08-01-2005, 02:18 PM   #5 (permalink)
HavockWK
HavockWK's Avatar
I don't know what it would do for your ability to haul 600# or your traction control, but getting rid of the overload leaf will save you about 30# (15# each side) I believe. Each one of those is significantly heavier than any of the individual leaves. Of course this is all by my rough estimations when we rebuilt my leaf springs for the PRG leaf pack install.
If you have problems with traction, ride quality and load capacity after removing the overload leaf, I recommend you look into the PRG leaf packs (15 lb each side which is about the same as the overload leaves) and then use the new PRG drop shackles to counter the 1.25" lift. Then you will have the capacity for hauling, better ride quality and better traction than with the stock overload leaf. I think they should work well with your Hellwig sway bar, but that is just a guess.
