Old 08-03-2005, 07:17 PM   #78 (permalink)
Nissanloyalist
Nissanloyalist's Avatar
Originally Posted by jdl75
Best wishes to you and your family! I guess it'll be a few months before you get pictures up!
How much cutting was required on the cab / body? Where did you mount the controller in the cab? My wife will go into labor when I buy the setup, and she's not even pregnant!
There was only one hole to drill. I ended up mounting the compressor inside the cab under the rear seat. I have 4 ga power line for my amps and I used that as my power source. This way I was able to mount the relay within three feet of the compressor as needed. If you mount the compressor outside the cab you need three lines into the cab. 2 air lines and one power line. If you do not have an amplifier I was thinking of mounting the compressor between the battery and the power steering fluid. The switch mounts great right below the steering wheel up against the hood latch. The whole install with bags and compressor was just under 4 hrs. The air line to the rear comes out of the firewall down the right front fender well to the frame were there is a bundle of wires I followed to the air bags. Seems like cheesy air line to be that exposed. No air leaks though. If I left anything out you would like to know just ask. I love them !!!
firestone-air-bags-anyone-got-theirs-truck-001.jpg  firestone-air-bags-anyone-got-theirs-truck-002.jpg  firestone-air-bags-anyone-got-theirs-truck-003.jpg
Nissanloyalist is online now   Reply With Quote
