Old 08-10-2005, 08:56 PM   #10 (permalink)
lizardking
Supporting Vendor (Gold)
At the time it was the only amp its size that can produce 85 watts RMS x 4 at 4ohm and have a THD rating of .004% with a signal to noise ratio of 105db. The amp is super clean and is capable of producing more power then its rated for. A very clean amp without a sticker shock price tag.. Soon I will be upgrading to the Zapco C2K 4.0X when I find a decent price. As for the other amp I have, Eclipse DA7232 I won't be getting rid of that ever.. That amp is sick and produces huge power without a lot of current draw and stays clean doing it not to mention its a two channel mono amp. The THD is rated at .005% with a signal to noise ratio of 120db. I could rattle even more specs on these amps but no need too. I wouldn't hesitate to recommend the DA7232 to anyone wanting a super clean amp with huge power. Capable of producing 1100-1200 watts RMS per channel depending on impedence load.
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
