And here's a few of the solenoids off the vehicle. The thing here is that the fitting that goes to the nitrous solenoid inlet is a "filter fitting". There is a mesh filter mounted inside of the fitting to prevent debris from entering the solenoid and causing any obstructions or possible leaks at the seal. I check it every time I take the system off the truck. It's a good idea to check it every bottle if you can get to it.
