Old 08-12-2005, 01:03 PM   #10 (permalink)
Sammy Sandbag
Sammy Sandbag's Avatar
Originally Posted by smoketitan
3)setting gains, if you have the cash its best to set them with a hand held oscilloscope, connect to the outputs, using some math you get the exact voltage amount you want to each speaker--youll never clip again
ive never had the la around cash to own one--so I do all my level matching by ear
clipping indicators will work also ,
use the multimeter to test voltage, ohm etc etc,
Yeah, but specifically how would I use a DMM to set the gains? Like I said, I also have the MATRIX so I could probablly run the gain all the way down on the amps and still have the max power to each amp.
-Counsel Yourself
