The OEM tuner was probably never designed for European FM standards. You will need to replace the head unit with an aftermarket one. You can order adapter kits which include a double-DIN bezel that will accomdate a single or double DIN head unit. The XE version of the Titan uses the same bezel. It's been said the OEM XE bezel is better fitting than an aftermarket one.
Another route is to get a separate tuner of some sort and connect it to the Aux input jack on the dash.
Good luck!
