Originally Posted by smkngtp99
i found the correct harness with the same number of pins in it but they are totally different. does the rockford system have anything to do with it
If you followed the wire from the bezel down to the first plug then followed that wire down to the next plug you should be at the right plug. The PAC instructions should work, that's what everyone has been following. There shouldn't be a difference in the RF or midline in that regards. Ill see if I can dig up anything from the manual.
