Well, this is somehow normal, the truck does not have a positive traction, so only one wheel pushes the truck so evertime you take off the truck leans onto the tire that is pushing thus bending the suspension in that corner, time after time.... if you look at an older Nissan hardbody, you will see that they all lean to one side...
See below link I mentioned it a year ago.
"http://www.titantalk.com/forums/showthread.php?t=17463&highlight=positive"
11-13-2004, 03:36 PM #4
cali-titan
Member Number: 2561
Posts: 143 The shocks will be in the same place only if it had a positive traction (posi) that is why some Domestic trucks 4x4 have them hung from the same place, in our case the Titan has aaaa... how is it called?.. an axle that powers only one wheel, (unless special conditions like going straight) so when you give gas only one wheel is pushing the truck and the rear shocks need to compensate for that..... when ever you drive behind a hardbody truck, you will see that it leans to one side, which is what will happen to our trucks once a few years go by. hope it helps.
XE CC Deep water.
